Discussion topic: The channel 751 is not working properly.
This message was authored by: Hedir
The voice in the TV channel is not linked with the actors mouth moving on the screen.
Re: The channel 751 is not working properly.
Obviously a problem with the channel directly @Hedir  nothing to fo with your Q box.
As the Subtitles do not match the language there are plenty of options for errors.
Noting you can do with your Q box.
Only option is to report the issue to Viewer relations but any improvement is unlikely I suspect.
[email protected]
