Discussion topic: Wifi connection for Qbox/minis
Message posted on 21 Jul 2023 05:07 PM
Since high winds and a power outage the Qbox isn't connected to the wifi (which is working) but we can get most TV channels but no apps.. We also have a booster and two minis which aren't connected to the router..Our internet/router is provided by an outside local company.
Should I just reboot the Qbox?
Message posted on 21 Jul 2023 05:13 PM
Re: Wifi connection for Qbox/minis
hi @catmat101
As your wifi if not SKY then the minis do not use your wifi but a wifi Signal generated by the main box
So, yes, try a power down restart of your main box, followed by your minis
Message posted on 21 Jul 2023 05:24 PM
Hi @catmat101
Is the booster a Sky Q Wifi booster?
If so where is it positioned and also to what are you connecting it?
