4
This discussion topic has been answered Discussion topic: The buttons on the remote for my multi room are mixed up
This message was authored by: Geoffrey99
I can switch on  my multi room box but then can't do anything. I can use the voice to select a channel and then some buttons work. But if I press the up arrow it works, but the home button works as the down arrow. The down arrow freezes the picture. The left arrow switches the remote off, etc.
Re: The buttons on the remote for my multi room are mixed up
Hi @Geoffrey99
Try removing the batteries and then press each button on the remote.
Replace the batteries and then  completely reset the mini remote as follows
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Hi @Geoffrey99
Avatar for Geoffrey99
I am unable to remove the casing on the remote in order to remove the batteries - there must be an easy way, but I can't find it
I took the batteries out, pressed all the buttons and put the batteries back. Pressed 7 and 9 tpogether forever and then 1 and 3, which just attempted to re-pair the box - I was unable to acknowledge the 'Continue' that was showing, because the middle button is still not working. I still just get the first picture and menu when I switch on the box and unable to continue beyond that screen.
Hi @Geoffrey99
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
