04 Apr 2024 07:05 PM
£90 cam out my bank for sky yet it's still not working
04 Apr 2024 07:14 PM
Hi @harridon28
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue have you tried rebooting your Q box?
If you still have no connection to the Internet try the following.
