This discussion topic has been answered Discussion topic: The Goos Wife
Message posted on 01 Feb 2025 03:03 PM
Hi does anyone know where the full boxset of The Good Wife is on Sky Q as I'm watching it on My5 via my TV
Message posted on 01 Feb 2025 04:14 PM
Hold that thought, I have done some further digging and all 7 seasons are on My5, but, the full My5 app isn't available on Sky Q yet.
So you can only see the Paramount+ search results because Q only has a selection of catch up content from Channel 5 currently.
Can you access the proper My5 app via your TV or another device?
If not, My5 is due to roll out on Sky Q at some point this month: https://rxtvinfo.com/2025/my5-launching-on-sky-q-ahead-of-big-rebrand/
Message posted on 01 Feb 2025 03:06 PM - last edited: 01 Feb 2025 03:11 PM
Re: The Goos Wife
@Burychurch15 wrote:Hi does anyone know where the full boxset of The Good Wife is on Sky Q as I'm watching it on My5 via my TV
I believe it is on Paramount+ currently, for which a basic subscription is included with Sky Cinema, or you can subscribe directly.
https://www.sky.com/watch/the-good-wife
Message posted on 01 Feb 2025 03:13 PM
Re: The Goos Wife
I've tried to type in The good Wife in the search box and it's only comes up with Paramount plus would getting in touch with My5 work?
Message posted on 01 Feb 2025 03:17 PM - last edited: 01 Feb 2025 03:17 PM
Re: The Goos Wife
@Burychurch15 wrote:I've tried to type in The good Wife in the search box and it's only comes up with Paramount plus would getting in touch with My5 work?
No, if you want to watch all of it now, you will need a Paramount+ subscription or wait to see if the rest of it becomes available on My5 at a later date.
My5 and Paramount+ have the same owners so they often put some episodes of a series on My5 to try and tempt you to watch the rest on Paramount+, which requires a subscription.
Message posted on 20 Feb 2025 06:51 PM
Re: The Goos Wife
My5 has appeared on my Sky Q box and the full box set of The Good Wife is available.
