2
This discussion topic has been answered Discussion topic: Technically
This message was authored by: Mems
Technically
My sky box keeps saying there has been a problem finding your sky Q box on the network.
Go to sky Q box and select Settings >Status.
where do I locate this?. The setting on the remote.
This message was authored by: Laing1 Answer
Re: Technically
@Mems press the home button on your remote then scroll down to settings press select then status
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Technically
Avatar for Mems
Re: Technically
Thank you!!!.
