Discussion topic: Technically fault
This message was authored by: Sarah284
Technically fault
Recently got a new box as old one was making a noise, now when watching, all off a sudden goes black And switches self off, turn it on again and say technical fault on every channel, till u turn it off and reboot it.
it's done this about 10 times a day,
Re: Technically fault
Hi @Sarah284
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
If you still have the same issue
Avatar for Sarah284
Thank you, will give it a go
