Discussion topic: We have sky q multi room and the 2nd box won’t connect
This message was authored by: James1718
Re: We have sky q multi room and the 2nd box won’t connect
@James1718 Have you tried rebooting your main Q box ie
then
rebooting your mini box
This message was authored by: bob1234
@James1718It depends on which main box you have the original 1TB boxes only supported one mini box.
