2
This discussion topic has been answered Discussion topic: Technical issue
This message was authored by: apnasat
Technical issue
Sky mini box not working with technical fault on screen
Avatar for apnasat
This message was authored by: apnasat Answer
Re: Technical issue
Tried all of that...
Had to go to main box and reset hard drive on main box and then all was sorted .. risk of losing recorded program's but I can always download again. It worked 💪 and I have both boxes working
Re: Technical issue
Hi @apnasat Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with the Mini box?
Avatar for apnasat
Re: Technical issue
