3
This discussion topic has been answered Discussion topic: No sound from box at all
This message was authored by: saintfreddy
My Sky Q box has lost all sound output, on tv or any apps. I cannot get output via my tv or sound system and both work fine on other devices. Ive checked all cables and reset the sky box in settings. I also restarted the box. Nothing works, any ideas?
Avatar for saintfreddy
This message was authored by: saintfreddy Answer
Re: No sound from box at all
To close the ticket for future reference: this was a fault caused by the TV HDMI controller which was incorrectly taking audio from a game console, whilst showing the sky box image. It resolved itself.
This message was authored by: GRU22
Good  morning
It looks like you have already gone though the motions, trying to fix yourself.
I would suggest doing a settings reset, though the settings tab.
If that fails, contact sky tech who will be able to do a full investigation.
Hope you get it all sorted.
Hi @saintfreddy
You could try Rebooting your TV set.
Failing this have you checked with Q box connected direct to TV and not through any sound system
