1
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: EmOD
Technical fault
The sly mini boxes keep coming up saying technical fault and can't connect to main box and TV screen goes blank with a blue background
This message was authored by: Laing1 Answer
Re: Technical fault
@EmOD Have you tried rebooting your main Q box ie
then
rebooting each of the minis
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Technical fault
then
