Discussion topic: Technical fault
Message posted on 04 Jun 2024 11:06 AM
Technical fault
Technical fault on black screen
also says insert veiwing card but card was never moved in fact nothing was touched
Message posted on 04 Jun 2024 11:10 AM
Re: Technical fault
@petermoore72
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Failing that, try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
