Discussion topic: Connect sky Q mini box in garden room
Message posted on 04 Jun 2024 10:03 AM
Broadband Router is fron of house.
Sky Q main Box centre of house.
Sky Q Mini Box in garden room some 20 meteres back at rear of house.
Wifi signal not strong enought to reach garden room.
Best way to connect the sky mini box is how?
Message posted on 04 Jun 2024 10:05 AM - last edited: 04 Jun 2024 10:06 AM
Re: Connect sky Q mini box in garden room
Ethernet cable, Powerline networking adapters or specialist point to point WiFi hardware making a wireless bridge to a local ethernet switch.
Message posted on 04 Jun 2024 10:10 AM
Hi @SnoooTwo
Ethernet is probably the best option. Exterior grade.
If you are Sky Broadband then the Ethernet can be either to the main Q box or the mini.
On 3rd party broadband you would have to connect the mini to the main Q box (unless all boxes are connected to the router by Ethernet)
Message posted on 04 Jun 2024 10:12 AM
Can the main box be connected via wifi and then the mini box by ethernet cable?
Message posted on 04 Jun 2024 10:13 AM
Message posted on 04 Jun 2024 10:20 AM
ethernet from the main box to the mini box is not a logistical option though
Message posted on 04 Jun 2024 10:25 AM
Message posted on 04 Jun 2024 10:27 AM
BT Broadband
Message posted on 04 Jun 2024 10:39 AM
I'm on BT
Message posted on 04 Jun 2024 10:52 AM
@SnoooTwo wrote:
I'm on BT
OK @SnoooTwo
that means you cannot connect the mini by Ethernet to the router if your Main Q box is on WiFi.
One option would be to use two Powerline units to connect the main Q box to your BT router. The main box and router need to on the same consumer unit.
Powerine is not guaranteed and depends heavily on the condition and complexity of your mains circuit. If it is successful then this would mean that the Main box is effectively on Ethernet and so the mini can then also be Ethernet connected to your router.
