Discussion topic: Technical fault
This message was authored by Gillw This message was authored by: Gillw
Technical fault
I keep getting a technical fault when watching recorded programmes. Can you help?
Re: Technical fault
Hi @Gillw
Have you tried rebooting the Q box?
Bear in mind that the issue may not be corrected on Existing records if they have failed due to a 'technical issue'
If you still have the same problem on new Recordings then try aReset Settings in the Q box hidden menu.
