Discussion topic: Sky mini box keeps freezing
Message posted on 17 Mar 2024 05:53 PM
Message posted on 17 Mar 2024 06:15 PM - last edited: 17 Mar 2024 06:16 PM
Re: Sky mini box keeps freezing
@John6636 wrote:
I'm having problems with my sky mini box it keeps freezing when try to watch a program the box was replaced a few months ago but this didn't make a difference
Hi @John6636
Reboot the mini as above.
Message posted on 23 Apr 2024 03:37 PM
HI
I have same problem ,Sky Q mini picture freezes , i have had 2 engineers out so far both saying connectivity if good ( i have a Sky router next door in bedroom ) Updates are all correct and inline with the main Qbox down stairs ,we did all the above ,switched off main ,reset mini and it works for about a week then picture freezes again .
I can watch other App like prime /netflix,Etc but not SKY programes ,movies etc .
I have changes the HDMI lead ,check power lead still nothing works ,so 2x engineers 2x new boxes , could it be the TV ? this is 3 years old samsung .
Didn't have this problem with he SKY HD box and same TV .
