Discussion topic: Sky q knocking off then don’t come back on for few days
Message posted on 23 Apr 2024 04:06 PM
Sky q keep knocking off every 5mins then won't come back on for a few days
Message posted on 23 Apr 2024 04:23 PM
Re: Sky q knocking off then don’t come back on for few days
Hi @Engine2
Does the Q box seem hot when it switches off?
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
