Discussion topic: Technical fault
This message was authored by: TheBigFella1985
Message posted on 14 Jan 2024 02:02 PM
Technical fault
Hi I have a message on my TV across all Sky channels, that says there is a technical fault with this channel.
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Jan 2024 02:43 PM
Re: Technical fault
@TheBigFella1985 Have you tried rebooting your main Q box ie
