12 Jan 2024 09:17 PM
What does this message mean?
please wait for your programme to load
12 Jan 2024 09:22 PM
Looks like an issue with your Q box connecting to your router @TJ45
Try a Network Reset found in Q box Home - Settings - Setup - Network.
12 Jan 2024 09:24 PM
Thanks! I have tried this a few times now buy to no avail.
14 Jan 2024 03:06 PM
Thank you for your reply and for your help! Appreciate you taking the time to respond. It worked!
