Discussion topic: Technical fault
This message was authored by Willuamkane1 This message was authored by: Willuamkane1
Technical fault
I have a main box in living room and two other boxes in both rooms .. they are playing up every time I come home I'm needing to switch everything off and on until I can connect properly.. it let  ok s a ting I've no signal but my box tells me different.. also my hub only has three green lights it used to have four other one won't light up .. it won't let me record programs either .. can you help pleas ?
