Discussion topic: My sky q box is over heating and not working
Message posted on 30 Dec 2023 11:27 AM
My sky q box is not working and i think it is overheating
Message posted on 30 Dec 2023 11:33 AM - last edited: 30 Dec 2023 11:34 AM
Re: My sky q box is over heating and not working
Have you changed its location and more importantly is it well ventilated? You should always be able to rest the palm of your hand down on the top of the box.
Message posted on 30 Dec 2023 11:34 AM
Is it enclosed in a cabinet or stacked with other devices?
Or is it in the open and well ventilated?
They do run quite warm but not so hot that you cannot hold your hand on them.
Message posted on 30 Dec 2023 11:42 AM
Hi thanks for the reply,
my sky box won't even connect to the TV so I can't press anything. I need an engineer to be sent out but i don't know how to do it. I've phones sky and they sent me to this sky community.
cheers,
alex
Message posted on 30 Dec 2023 11:45 AM
If you definitely need an engineer you'll have to persevere on the phone. If you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Just stay on the line and you should join a queue.
Note: We were informed on the run up to Christmas the lines were busier than usual and that’s likely to be worse over the holiday period.
