Discussion topic: Technical fault
This message was authored by: Blaina
Technical fault
I gave a technical fault on my TV, can you help please
Re: Technical fault
@Blaina you will need to give us more information what is the fault you are having is it with your actual Sky box or your TV
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
