2
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: David259
Technical fault
Technical fault on screen what do I do
Re: Technical fault
Hi @David259
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Re: Technical fault
@David259  Have you tried a power reboot?  Unplug the Sky Q box/mini for a minute or so then plug back in.
If it's just the mini showing this unplug both, power up the main box 1st wait until fully rebooted then do the same with the mini.
Re: Technical fault
Hi @David259
Answered - Go to Answer
