Discussion topic: Technical fault
This message was authored by: lyndie1409
Technical fault
My sky q yesterday would not connect to my internet now it's got no picture and says technical fault
Re: Technical fault
@lyndie1409
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
If that doesn't help take a look at this link
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/an-on-screen-message-sky-q/articles/there...
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
