5
This discussion topic has been answered Discussion topic: Sky box moved & cable for another box
This message was authored by: Amra
I need my sky box moved & another sky box installed in another room.
This message was authored by: daveNOS Answer
Re: Sky box moved & cable for another box
@Amra You will have to call Sky to request an engineer visit, there will be a charge for that I believe it's £65 and be prepared for it not to be before the new year.
Avatar for Amra
It's ok,
I managed to speak to someone at Sky.
it is getting sorted out.
Thank you for your help 👍🏼
This message was authored by: Funky_badger
Thanks for this. I have the same requirement (to move my main box to another room). Appreciate I need to call Sky for an engineer to come, and that there will be a charge. What I can find is the phone number! Do you know what number I need to call? Many thanks
hi @Funky_badger
If you have the MY SKY app I think you may be able to find a number there - especially if you are a SKY VIP member
If not go this page & scroll to the bottom and expand the link need more help & scroll down
https://www.sky.com/help/home
If you have SKY Mobile or SKY Talk land line then I think you can also call 150
Many thanks 🙂
