Discussion topic: Technical fault whilst replaying recorded programs. This includes old programs.
This message was authored by: Disgruntled3
Re: Technical fault whilst replaying recorded programs. This includes old programs.
@Disgruntled3
First thing to perhaps try is a reboot of the box. Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
@Disgruntled3 wrote:
Hi @Disgruntled3
