Discussion topic: Technical fault while watching recorded programs
This message was authored by: VNessa
While watching recorded programs, but not all recorded programs, I am getting a blue screen which displays a message informing me there is a technical fault.
I have restarted the router, as advised, but it still keeps happening.
How do I resolve this issue?
Re: Technical fault while watching recorded programs
Hi @VNessa
Try a Reset Settings in the main Q box hidden menu.
