Discussion topic: Technical fault can’t get itv it says try again later
This message was authored by: Sebby2016
There is a technical fault with this channel (itv) please try again later. This is the message on screen
Re: Technical fault can’t get itv it says try again later
Hi @Sebby2016 .
Have you tried rebooting your Q box?
@Sebby2016
Also see the below link
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Avatar for Sebby2016
Level 0 icon
That's worked thanks
