Discussion topic: Technical fault can’t get itv it says try again later
Message posted on 04 Sep 2024 07:13 PM
There is a technical fault with this channel (itv) please try again later. This is the message on screen
Message posted on 04 Sep 2024 07:18 PM
Re: Technical fault can’t get itv it says try again later
Hi @Sebby2016 .
Have you tried rebooting your Q box?
Message posted on 04 Sep 2024 07:22 PM
Also see the below link
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 04 Sep 2024 07:25 PM
That's worked thanks
