Discussion topic: Technical faul
This message was authored by: Ja46
Technical faul
Technical fault with this channel Please try again later.
this also happens with recordings
This message was authored by: PSK2
Re: Technical faul
Mine is doing this as well
Re: Technical faul
@PSK2 @Ja46
What channel and what device is this on,, Sky Q, Glass or Stream ?
Avatar for Ja46
Re: Technical faul
This is on SkyQ
Re: Technical faul
Thanks, I have moved this to the Sky Q board on here for you.
Re: Technical faul
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
