Discussion topic: Technical faul
Message posted on 15 May 2025 04:32 PM
Technical faul
Technical fault with this channel Please try again later.
this also happens with recordings
Message posted on 15 May 2025 04:42 PM
Re: Technical faul
Mine is doing this as well
Message posted on 15 May 2025 04:45 PM
Re: Technical faul
What channel and what device is this on,, Sky Q, Glass or Stream ?
Message posted on 15 May 2025 04:50 PM
Re: Technical faul
This is on SkyQ
Message posted on 15 May 2025 05:07 PM
Re: Technical faul
Thanks, I have moved this to the Sky Q board on here for you.
Message posted on 15 May 2025 05:11 PM
Re: Technical faul
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
