Discussion topic: Tech issue code WGT8
This message was authored by: Cliffers
Message posted on 28 Sep 2024 01:02 PM
How do I correct a technical issue code WGT8
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 28 Sep 2024 01:37 PM
Re: Tech issue code WGT8
@Cliffers you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
