Discussion topic: TV satellite issues
Message posted on 07 Jan 2025 07:51 PM
TV satellite issues
Message posted on 07 Jan 2025 07:53 PM
Re: TV satellite issues
@Mayor
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
