Discussion topic: TV satellite issues
This message was authored by: Mayor
TV satellite issues
My satellite signal is is poor and keeps effecting most of my sky channels
Re: TV satellite issues
@Mayor
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
