Discussion topic: TV not programmed
This message was authored by: Skiathos64
TV not programmed
For 4 days this has not been working there is no telephone number or help! Pleease help me!!
Re: TV not programmed
Can you explain exactly what's showing this message?  It sounds like it's your TV rather than Sky.
@Skiathos64
"TV not programmed" is usually the television informing you that it is not receiving digital terrestrial (Freeview) television through its built-in tuner.
The signal from a Sky box should be arriving over an HDMI input, not a tuner: try using the television remote to change input selection.
