Discussion topic: Q box not recording
This message was authored by: Crestycrazy
Q box not recording
Brand new box but it will not record or download any programmes
Re: Q box not recording
Are you trying to access HD without the HD pack?
Any errors?
Hi @Crestycrazy Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot.
