5
This discussion topic has been answered Discussion topic: TV guide layout
This message was authored by: Jo+Powell+2
TV guide layout
Can I change the order of the menu?  I would like Apps to be higher up the menu and then certain Apps to be higher up that menu (or even pinned to the home menu somehow).
Re: TV guide layout
@Jo+Powell+2
No, the Home page and/or epg can't be changed.
Re: TV guide layout
@Jo+Powell+2
Re: TV guide layout
Hi @Jo+Powell+2   The Apps are shown on the Home page, ordered by most recent used. Scroll down. The Home page is different to the TV Guide.
Re: TV guide layout
Try your voice remote to open apps quicker...
This message was authored by: best+of+the+best
Re: TV guide layout
Wouldn't it be easier to use the voice remote and open your apps that way.
Apps are on the home screen but by the time I've scrolled down and selected one using the voice remote does it quicker but each too their own I guess.
Avatar for Jo+Powell+2
Re: TV guide layout
Thanks. Voice remote doesn't seem to be working anymore. Will try and reset.
Answered - Go to Answer
