Discussion topic: Can’t access recordings on my sky q mini box
This message was authored by: J20afhtdvju
Can't access my recordings on mini box it just says please wait
Re: Can’t access recordings on my sky q mini box
Reboot the main box and then do the same with the mini
Avatar for J20afhtdvju
Yeah did that it turns out my hard drive on the main box has died. But thank you.
Hi @J20afhtdvju
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
@J20afhtdvju
In that case, if Sky arrange a 'doorstep box swap' whereby a courier company (DPD in the UK) deliver a new box and take your faulty box away, remember to remove the viewing card from the old box before it disappears into the van.
