Discussion topic: Sky
This message was authored by: Lukeuk
Sky
My sky has been playing up over the past week. My sky Q mini has been playing up for ages always losing connection
Re: Sky
Hi @Lukeuk
Try a Reset Settings in the main Q box hidden menu.
If the mini is still losing connection try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
This message was authored by: Invisiblename
Re: Sky
Apart from making it sit on the 'naughty step', what do you mean by "playing up"?
I am just another Sky customer!
