Discussion topic: TV Guide missing
Message posted on 21 Feb 2024 08:16 AM
TV Guide missing
My TV guide is getting worse daily with missing channels . I have checked it's in eco mode I have even replaced the LNB . I have reset whole system loads of times and still channels missing so therefore some of things I want to record are not recording either
Message posted on 21 Feb 2024 09:15 AM
Re: TV Guide missing
You say you've reset the whole system - do you mean you've rebooted the box which normally cures this
~ press the 🏠 button
HAPPY NEW YEAR
Message posted on 21 Feb 2024 09:22 AM
Yes I have also done that
Message posted on 21 Feb 2024 09:25 AM
Having the standby settings set to eco mode shouldn't impact the epg display. Who changed the LNB for you?
HAPPY NEW YEAR
Message posted on 21 Feb 2024 09:47 AM
I did and I have a satalite finder to ensure it's correct
Message posted on 21 Feb 2024 10:12 AM - last edited: 21 Feb 2024 10:14 AM
Hi @Pauline51
Are you sure it is a Sky Q Wideband LNB.
These are different to the old Sky plus LNB's.
If you are sure it is the correct type and you are missing channels one of the cables may not be functioning. One will carry vertical polarised channels and the other horizontal.
Check the F connectors at both ends of each cable to make sure the central cable conductor is not bent or touching any part of the cable wire shield or connector casing.
Failing this the LNB may be faulty
Message posted on 21 Feb 2024 11:44 AM
Thank u for responding.
LNB is a wide and LNB. When I put it up I ensured nothing was wrong with cables. I am absolutely at a lose with it and very frustrating
Message posted on 21 Feb 2024 12:50 PM
Hi @Pauline51
Have you checked whether or not the missing channels are all the Same polarisation?
Message posted on 21 Feb 2024 12:58 PM
How do I check this
Message posted on 21 Feb 2024 01:19 PM
@Pauline51 wrote:
How do I check this
Hi @Pauline51
See the channel transponders in the following link
