Discussion topic: TV Guide missing
This message was authored by: Pauline51
TV Guide missing
My TV guide is getting worse daily with missing channels . I have checked it's in eco mode I have even replaced the LNB . I have reset whole system loads of times and still channels missing so therefore some of things I want to record are not recording either
Re: TV Guide missing
@Pauline51
You say you've reset the whole system - do you mean you've rebooted the box which normally cures this
~ press the 🏠 button
HAPPY NEW YEAR
Avatar for Pauline51
Yes I have also done that
@Pauline51
Having the standby settings set to eco mode shouldn't impact the epg display. Who changed the LNB for you?
HAPPY NEW YEAR
I did and I have a satalite finder to ensure it's correct
Hi @Pauline51
Are you sure it is a Sky Q Wideband LNB.
These are different to the old Sky plus LNB's.
If you are sure it is the correct type and you are missing channels one of the cables may not be functioning.  One will carry vertical polarised channels and the other horizontal.
Check the F connectors at both ends of each cable to make sure the central cable conductor is not bent or touching any part of the cable wire shield or connector casing.
Failing this the LNB may be faulty
Thank u for responding.
LNB is a wide and LNB. When I put it up I ensured nothing was wrong with cables. I am absolutely at a lose with it and very frustrating
Hi @Pauline51
Have you checked whether or not the missing channels are all the Same polarisation?
How do I check this
@Pauline51 wrote:
How do I check this
Hi @Pauline51
See the channel transponders in the following link
https://en.satexpat.com/tv/uk/sky/
