Discussion topic: TOTP recordings on sky box
Message posted on 22 Jun 2025 12:23 PM
This happens often, then it's fixed and then it happens again. Can these recordings automatically be added to the TOTP folder instead of scattered like this? Thanks.
Message posted on 22 Jun 2025 12:29 PM - last edited: 22 Jun 2025 12:30 PM
Re: TOTP recordings on sky box
The titles are different ie; TOTP 1986 or TOTP 1998 so the answer is no I'm afraid. The ones with the same year might if you reboot the box so
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 22 Jun 2025 01:23 PM
Hi @saileshr A reboot of your broadband router to refresh its DNS sometimes helps. Don't expect any retrospective fixes, but ongoing may help. Note this is a 9 year old problem that reappears every now and then.
Message posted on 22 Jun 2025 02:24 PM
They are disparate on mine too - I presume it's a metadata issue but Sky and BBC may well blame each other...
Message posted on 22 Jun 2025 04:00 PM
They have been bunched together before and usual are, but every now and then this happens.
Message posted on 22 Jun 2025 08:00 PM
@saileshr as @MightyQuinn advises reboot your router and then your main Q box this may help going forward but retrospectively the ones that have not stacked will not restack
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
