Discussion topic: TNT stuttering
This message was authored by: Nat2102
TNT stuttering
My tnt on sky is stuttering and freezing and blurring it has been doing this over a month now and no other channel is except the by sports ones which I pay extra for is there a reason for this I need to fix it 🙏
Re: TNT stuttering
Yep, been quite a bit of this.
Assuming a box reboot (unplug at the mains for at least 5 minutes), doesn't fix it, then your dish may well be slightly out of alignment and you will need an engineer.
In the meantime you can watch via discovery+ in up to UHD assuming you have activated it. The app is on your Q box.
