Discussion topic: TNT sports subscription - no hd channels
Message posted on 20 Sep 2025 12:42 PM
I signed up last Wednesday to tnt sports through sky box. I watched the champions league on the ultimate hd channel no issues, I can view the as channels but not tnt sports hd channels
Message posted on 20 Sep 2025 12:44 PM
							Re: TNT sports subscription - no hd channels
Sd channels view ok, the uhd channel ok, not the hd ones
Message posted on 20 Sep 2025 04:16 PM
@Drminta what happens when you try to watch the HD channels
Message posted on 24 Sep 2025 07:28 PM
It says no satellite signal. Same message on tnt hd channels 1 2 and 3. All other channels work fine
Message posted on 24 Sep 2025 08:44 PM
@Drminta wrote:It says no satellite signal. Same message on tnt hd channels 1 2 and 3. All other channels work fine
Most likely a dish issue. The TNT HD channels are amongst the first affected by a slight dish misalignment.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 26 Sep 2025 08:13 AM
Ah so that's a sky helpdesk task to raise then?
