Discussion topic: TNT 5
Message posted on 14 Jan 2026 12:16 PM
Re: TNT 5
I pay BT.......just logged into to BT account where it says "activate" Discovery +. But nothing happens when I click it and I can get Discovery + on Sky anyway. So frustrating sometimes! Thanks to all for trying to help.
Message posted on 14 Jan 2026 01:19 PM
Re: TNT 5
If you are getting discovery+ on Sky you may be getting it as part of your Sky package which in your case you get TNT sports though bt is just the basic discovery+ , which dose not include live sport. What you need to do is log out of discovery + and then log in with your login details for you BT account for tnt sports that will then give you access to TNT channels though the discovery +app including the extra ones that are not on Sky tv guide.As you pay bt for TNT sport I am not sure if red button will work though this only takes you to the discovery+ app any way so it might work
Message posted on 14 Jan 2026 01:24 PM
Re: TNT 5
@Rogbad wrote:I pay BT.......just logged into to BT account where it says "activate" Discovery +. But nothing happens when I click it and I can get Discovery + on Sky anyway. So frustrating sometimes! Thanks to all for trying to help.
If you had answered that clearly when I asked you specifically in post 3, we would have solved this by now...😞
