Discussion topic: Symbol on tv screen
Message posted on 24 Jul 2023 02:06 PM
							Symbol on tv screen
Just changed from Sky entertainment package to Sky Signature. A symbol has now appeared on screen
- a grey circle with a line across (see pic attached). How do I get rid of it?
Message posted on 24 Jul 2023 02:17 PM
							Re: Symbol on tv screen
@Fiverdog I suspect that is coming from your TV, not Sky.
Message posted on 24 Jul 2023 02:23 PM
I don't think so because when I use my tv remote instead of the Sky remote the symbol disappears.
Message posted on 24 Jul 2023 02:33 PM
@Fiverdog wrote:I don't think so because when I use my tv remote instead of the Sky remote the symbol disappears.
I think that's a large clue it is the TV...
Message posted on 24 Jul 2023 03:38 PM
That's confirmation that it's from your TV then
Message posted on 24 Jul 2023 03:46 PM
Given that info then it is clearly your TV and not your Sky box.
Message posted on 24 Jul 2023 05:01 PM
Thought I'd found the problem. Using the tv remote I discovered the tv wasn't connected to the wifi - great I thought, that's probably the problem. After a frustrating hour got the wifi to connect with the tv ... alas, the symbol remains. Now the tv remote won't work! Looks like we'll have to live with it. 😡
Message posted on 24 Jul 2023 05:26 PM - last edited: 24 Jul 2023 05:26 PM
Are you using an external soundbox or bar?
To me that looks like an attempt to indicate onboard television speakers are muted.
Message posted on 26 Jul 2023 11:40 AM
The tv is connected to a speaker and a soundbar. There doesn't appear to be any sound from the speaker but the soundbar is working ok. Will continue investigating! Thanks. 🤣
Message posted on 26 Jul 2023 11:55 AM
That looks like the symbol LG TVs show when the speaker is muted. It's definitelty something from the TV in any case and not Sky related.
