Discussion topic: Switching to HD+ box temporailiy once SKY Q installed?
This message was authored by: pra29
Getting our new Sky Q box this coming week.  One question: Following installation i will still have my old SKY HD+ box with a number of recordings on it.  I'm aware that I cannot transfer these and that I 'could' copy them to DVD, but I'd like to know if it were possible to simply change the cable from the Q box to my old machine for a couple of weekends in order to watch these recordings.  I suspect that the replacement card prevents this but is that so?
Re: Switching to HD+ box temporailiy once SKY Q installed?
@pra29
You won't be able to watch your recordings remaining on your Sky+ box I'm afraid.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Avatar for pra29
Level 3 icon
Thanks. I suspected as much - SKY are not exactly customer focused are they!
@pra29 I'm not defending Sky but there are technical reasons for this as well namely if your HD box hasn't had a satellite signal for a number of days it won't work until it recognises a satellite signal. As the LNB has been changed then even if you attache the satellite cable it will still not receive a signal
