17 Feb 2024 09:34 PM
Suddenly at 21.20 the main sky box froze in channel 103 and all
mini boxes reported "Texhnical Falult". Turn off and on and the main sky box is now working but all mini boxes still reporting technical fault. Anyone else hit with this or is this specific to me?
17 Feb 2024 09:44 PM - last edited: 17 Feb 2024 09:45 PM
Hi @Keithb307
Reboot the minis as above.
18 Feb 2024 11:15 PM
Thanks @oldfella turns out I have a slightly different problem. So we've upgraded from a 1TB box to a 2TB box. A new mini box is now also situated in a room above another old existing mini box. Because of its proximity, the the old box (in a room downstairs) is now "seeing" the mini box upstairs and trying to link to the Ethernet through that, rather than the booster. Net result the "noise" by linking through a mini box rather than the booster is too high and it results in a connectivity problem. Anyone got any ideas on how to make a mini box communicate ONLY with the booster rather than a nearby mini box??? All input welcome.
19 Feb 2024 06:37 AM
@Keithb307 wrote:Thanks @oldfella turns out I have a slightly different problem. So we've upgraded from a 1TB box to a 2TB box. A new mini box is now also situated in a room above another old existing mini box. Because of its proximity, the the old box (in a room downstairs) is now "seeing" the mini box upstairs and trying to link to the Ethernet through that, rather than the booster. Net result the "noise" by linking through a mini box rather than the booster is too high and it results in a connectivity problem. Anyone got any ideas on how to make a mini box communicate ONLY with the booster rather than a nearby mini box??? All input welcome.
Turn the new mini off, get it all working with the mini, booster and Q and once stable try re-adding the new mini.
How do you know it's trying to connect via the new mini, by the way? Q's wifi networking will try to reconfigure itself so the above may not behave predictably once the new mini is back on.
and when you say "ethernet", where is that in this setup?
19 Feb 2024 09:39 AM
Hi @Keithb307
Provided it is a Sky Q booster (and connected through a Sky Broadband hub) there is no such thing as noise and the connected mini and the booster are all part of the Q mesh.
If you are not on Sky broadband or the booster is not a Sky Q booster; then the problem mini will only connect to the main Q box or the already connected mini.
19 Feb 2024 09:57 AM
Hmmm, I'm on BT broadband (full fibre). When the glitch happened again last night we ran a Network Scan with the sky help desk and determined that the db noise (their description - ie signal too weak ) on this specific box was too high - it seemed to be connecting through the mini box in the room above (which is closer than the booster) rather than to the Sky booster. Disconnecting the mini box above and everything else works brilliantly again). Restart and reconnect the new upstairs mini box again once everything else is stable, and the downstairs mini box has a problem again.
19 Feb 2024 10:01 AM
Ps the reference to Ethernet was how the sky help desk identified the mini box which was having the problem (Mac Ethernet Address) which is apparently a unique address to each mini box. Appreciate that I may have misunderstood what that meant 🙂
19 Feb 2024 10:02 AM - last edited: 19 Feb 2024 10:05 AM
Hi @Keithb307
You need to explain how the three Q boxes are connected. As @Chodley asked where does the Ethernet go? Edit OK you have confirmed no Ethernet connections
Also how is the Sky Q booster connected?
19 Feb 2024 10:11 AM - last edited: 19 Feb 2024 10:14 AM
Posted by a Superuser, not a Sky employee. Find out moreYeah I don't know why they mentioned ethernet with respect to the MAC address of the mini. Physical ethernet sockets/adapters have MAC addresses but so do wifi tranceivers so the term ethernet isn't relevant in that context.
Ref noise, what they may have said is SNR (signal to noise ratio which is definitely a real thing in radio comms including wifi)
This might sound counter intuitive but maybe blocking the path between the two minis with something metallic might dissuade it from choosing that connection path (as long as it doesn't also block either of them from the booster or Q, whichever they are connected to). E.g. could you hide a sheet of foil in a drawer underneath the upstairs one?
Did the Sky helpdesk person not offer any possible solution when they spotted what was happening?
19 Feb 2024 10:57 AM
Hi @Chodley
The only thing is that the Q mini signal is not Noise.
It is the WiFi that Q boxes will connect to and doesn't want blocking.
Still trying to ascertain what his booster is and how and to what it is connected.
19 Feb 2024 01:16 PM
19 Feb 2024 06:41 PM
@oldfella wrote:
@Chodley wrote:Yeah I don't know why they mentioned ethernet with respect to the MAC address of the mini. Physical ethernet sockets/adapters have MAC addresses but so do wifi tranceivers so the term ethernet isn't relevant in that context.
Hi @Chodley
I know. I was suggesting blocking mini1-mini2 not mini-Q or mini-booster.
