Discussion topic: When watching tv via minibox picture keeps freezing
This message was authored by: Brough007
Picture keeps freezing when watching sky via my minibox main TV downstairs is working fine... tried resetting minibox tried reconnecting minibox to network but still the same problem
Re: When watching tv via minibox picture keeps freezing
Reboot the mini as above.
