Discussion topic: Subtitles Issue.
Message posted on 05 Sep 2024 06:01 PM
							Subtitles Issue.
Had a new Sky Q Box installed less than 48 hours ago and already I'm having issues. I activated subtitles by voice command and now I can't get the subtitles to go off. I go to the ? button on my remote and scroll along to Subtitles which are set to 'English'. I select 'off' and the subtitles do go off - but only for the channel I'm currently watching. But when I change channels the Subtitles are ON and when I go back to the channel I was watching the Subtitles are back ON.
Also, I can't get 'record series'. Instead all I can get is 'Record Once'.
And the box has already recorded programmes I did not set to record.
Anyone any ideas ? Please help.
Message posted on 05 Sep 2024 06:12 PM - last edited: 05 Sep 2024 06:19 PM
							Re: Subtitles Issue.
Hi @Garry+Rowe
The Subtitles have two states, 1. Default and 2. Temporary. When you turn them off and on using the "?" route this is temporary. Changing channel will restore to default. However, if you use the voice command you change the Default. The same as changing in the Accessibility settings. So voice command "Subtitles On (or Off)" permanently changes the default state for all channels and programmes with subtitles.
Not all programmes or channels have a Series link. Do you have an example?
I would go into the Scheduled programmes and tidy up any spurious scheduled programmes.
Message posted on 05 Sep 2024 06:15 PM
I tried using voice command and saying 'Subtitles Off' more than once but it only picks up 'Subtitles' and not the the word 'Off.'
Message posted on 05 Sep 2024 06:16 PM
You should also be able to switch on & off from :
Home - Settings - Accessibility - Subtitles
Message posted on 05 Sep 2024 06:17 PM
OK, I'll try that.
Message posted on 05 Sep 2024 06:19 PM
Thank you, it worked.
Any ideas on the other issues I mentioned?
Message posted on 05 Sep 2024 06:20 PM
Hi @Garry+Rowe
I have the same problem here with Voice control.
I have to say Subtitles oorf
Message posted on 05 Sep 2024 06:23 PM
@Garry+Rowe wrote:I tried using voice command and saying 'Subtitles Off' more than once but it only picks up 'Subtitles' and not the the word 'Off.'
Hi @Garry+Rowe I just tried "Subtitles Off". I had to put real emphasis on "Off" which worked. 1st time it showed Subtitles Of. Just checking that you are holding down the voice button until after completing Off.
Message posted on 05 Sep 2024 06:24 PM
Yeah, I'm holding it down for the required time span.
Message posted on 05 Sep 2024 06:29 PM
@Garry+Rowe wrote:Any ideas on the other issues I mentioned?
Hi @Garry+Rowe Sorry, I did edit my first reply.
For Series Record is it affecting all recordings - sometimes individual programmes are not correctly set up to link
Is it both on setting initially to record and also when using the manage Recordings - scheduled and trying to add a series link there.
Regarding recordings you have not set it is possible that the box is a used box and remembering 'smart' links used by the previous user - probably best to just keep an eye on scheduled recordings then remove any Series Links fisrt before deleting the recording due
(Alternatively use a bit more of a sledge hammer to do a reset of the box which we can advise if you really want to)
Message posted on 06 Sep 2024 04:04 PM
I was told by the engineers that it was a brand new box but who knows?
