Discussion topic: Stuck screen
This message was authored by: gemma54
Stuck screen
Sky q mini stuck on recordings screen
Re: Stuck screen
Hi @gemma54   Have you tried a power reboot?
Re: Stuck screen
Hi @gemma54
First make sure that the Sky button at the top of the mini remote hasn't stuck in.
If it is OK try rebooting the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Avatar for gemma54
Level 0 icon
Re: Stuck screen
Yes. It is a mini box upstairs so only gets used at night I have rebooted for the last 3 nights and it has been turned off through the day at the mains until I try again at night
Avatar for gemma54
Level 0 icon
Re: Stuck screen
Omg thank you old fella that worked...now I feel a right numpty
